跳转到主内容
RedOctane X-Plorer Strum Bar Sensor Board Replacement
你所需要的
  1. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: 步骤 1 中的图像 1,2 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 2 中的图像 1,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 2 中的图像 2,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 3 中的图像 1,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 3 中的图像 2,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: 步骤 3 中的图像 3,3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: 步骤 4 中的图像 1,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: 步骤 4 中的图像 2,3 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: 步骤 4 中的图像 3,3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
结论
另外一个人完成了本指南。
Riley
于04/18/18注册
703 声望
创作了7篇指南
团队
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 28
总计 3,188
