跳转到主内容
RedOctane X-Plorer Rubber Button Strip Replacement
你所需要的
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 步骤 1 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 步骤 1 中的图像 2,2
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 2 中的图像 1,1
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 3 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 3 中的图像 2,2
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 4 中的图像 1,1
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 5 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 5 中的图像 2,2
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 1.5 mm Screwdriver
    $5.49
    购买
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 7 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 7 中的图像 2,2
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 8 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 8 中的图像 2,2
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 9 中的图像 1,2 RedOctane X-Plorer Rubber Button Strip Replacement: 步骤 9 中的图像 2,2
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
结论
Stephen Haning
于09/30/21注册
169 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 225
