跳转到主内容
加入维修社区 - 创建账户
RedOctane X-Plorer Front Case Replacement
你所需要的
  1. RedOctane X-Plorer Front Case Replacement, Rear Case: 步骤 1 中的图像 1,2 RedOctane X-Plorer Front Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    询问修复机器人
  2. RedOctane X-Plorer Front Case Replacement: 步骤 2 中的图像 1,3 RedOctane X-Plorer Front Case Replacement: 步骤 2 中的图像 2,3 RedOctane X-Plorer Front Case Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    询问修复机器人
  3. RedOctane X-Plorer Front Case Replacement: 步骤 3 中的图像 1,3 RedOctane X-Plorer Front Case Replacement: 步骤 3 中的图像 2,3 RedOctane X-Plorer Front Case Replacement: 步骤 3 中的图像 3,3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    询问修复机器人
  4. RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 步骤 4 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 步骤 4 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 步骤 4 中的图像 3,3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
    询问修复机器人
  5. RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 步骤 5 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 步骤 5 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 步骤 5 中的图像 3,3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
    询问修复机器人
  6. RedOctane X-Plorer Front Case Replacement, Keys: 步骤 6 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, Keys: 步骤 6 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, Keys: 步骤 6 中的图像 3,3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
    询问修复机器人
  7. RedOctane X-Plorer Front Case Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, remove the rubber pad to expose the colored keys.
    询问修复机器人
  8. RedOctane X-Plorer Front Case Replacement: 步骤 8 中的图像 1,2 RedOctane X-Plorer Front Case Replacement: 步骤 8 中的图像 2,2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
    询问修复机器人
  9. RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 步骤 9 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 步骤 9 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 步骤 9 中的图像 3,3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
    询问修复机器人
  10. RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 步骤 10 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 步骤 10 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 步骤 10 中的图像 3,3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
    询问修复机器人
  11. RedOctane X-Plorer Front Case Replacement: 步骤 11 中的图像 1,2 RedOctane X-Plorer Front Case Replacement: 步骤 11 中的图像 2,2
    • Using one hand, remove the whammy bar and its attached components from the case.
    询问修复机器人
  12. RedOctane X-Plorer Front Case Replacement: 步骤 12 中的图像 1,1
    • Using two hands, remove the whammy bar sensor.
    询问修复机器人
  13. RedOctane X-Plorer Front Case Replacement, Motherboard: 步骤 13 中的图像 1,3 RedOctane X-Plorer Front Case Replacement, Motherboard: 步骤 13 中的图像 2,3 RedOctane X-Plorer Front Case Replacement, Motherboard: 步骤 13 中的图像 3,3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
    询问修复机器人
  14. RedOctane X-Plorer Front Case Replacement, Front Case: 步骤 14 中的图像 1,2 RedOctane X-Plorer Front Case Replacement, Front Case: 步骤 14 中的图像 2,2
    • Remove the four 12mm Phillips #1 that connect the body to the neck using a screwdriver.
    询问修复机器人
  15. RedOctane X-Plorer Front Case Replacement: 步骤 15 中的图像 1,1
    • Remove the neck panel from the front body panel.
    询问修复机器人
结论
Riley
于04/18/18注册
703 声望
创作了7篇指南
团队
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 81
总计 1,178
