跳转到主内容
RedOctane X-Plorer Auxiliary Port Replacement
你所需要的
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: 步骤 1 中的图像 1,2 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: 步骤 2 中的图像 1,3 RedOctane X-Plorer Auxiliary Port Replacement: 步骤 2 中的图像 2,3 RedOctane X-Plorer Auxiliary Port Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: 步骤 3 中的图像 1,3 RedOctane X-Plorer Auxiliary Port Replacement: 步骤 3 中的图像 2,3 RedOctane X-Plorer Auxiliary Port Replacement: 步骤 3 中的图像 3,3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 步骤 4 中的图像 1,3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 步骤 4 中的图像 2,3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: 步骤 4 中的图像 3,3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
结论
Riley
于04/18/18注册
703 声望
创作了7篇指南
团队
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G1
3 名成员
创作了9篇指南
1指南评论
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 1,466
