跳转到主内容
RedMax Trimmer Carburetor Replacement
你所需要的
  1. RedMax Trimmer Carburetor Replacement, Carburetor: 步骤 1 中的图像 1,3 RedMax Trimmer Carburetor Replacement, Carburetor: 步骤 1 中的图像 2,3 RedMax Trimmer Carburetor Replacement, Carburetor: 步骤 1 中的图像 3,3
    • Locate the red knob that locks the air filter cover to the air filter housing.
    • Rotate the knob clockwise.
    • Remove the air filter cover, exposing the air filter.
  2. RedMax Trimmer Carburetor Replacement: 步骤 2 中的图像 1,2 RedMax Trimmer Carburetor Replacement: 步骤 2 中的图像 2,2
    • Remove the air filter by gently pulling it away from the unit.
  3. RedMax Trimmer Carburetor Replacement: 步骤 3 中的图像 1,3 RedMax Trimmer Carburetor Replacement: 步骤 3 中的图像 2,3 RedMax Trimmer Carburetor Replacement: 步骤 3 中的图像 3,3
    • The red panel hides a second screw. In order to expose it, locate the red choke lever on the right side of the air filter housing.
    • Push the red choke lever down.
  4. RedMax Trimmer Carburetor Replacement: 步骤 4 中的图像 1,3 RedMax Trimmer Carburetor Replacement: 步骤 4 中的图像 2,3 RedMax Trimmer Carburetor Replacement: 步骤 4 中的图像 3,3
    • Be aware that there may still be gasoline in the lines.
    • Disconnect the yellow and black fuel lines from the carburetor assembly by pinching the clamp and sliding it down the tube.
    • Gently pull the yellow and black lines away from the assembly.
  5. RedMax Trimmer Carburetor Replacement: 步骤 5 中的图像 1,3 RedMax Trimmer Carburetor Replacement: 步骤 5 中的图像 2,3 RedMax Trimmer Carburetor Replacement: 步骤 5 中的图像 3,3
    • Using the T27 screwdriver, unscrew the two 55mm screws that hold the air filter housing and carburetor to the trimmer.
    • Separate the carburetor from the trimmer and air filter housing.
  6. RedMax Trimmer Carburetor Replacement: 步骤 6 中的图像 1,3 RedMax Trimmer Carburetor Replacement: 步骤 6 中的图像 2,3 RedMax Trimmer Carburetor Replacement: 步骤 6 中的图像 3,3
    • Unscrew the four 24 mm long screws that hold the carburetor together, using the #1 Phillips head screw driver.
    • Once the screws are removed, the rest of the carburetor should separate easily.
  7. RedMax Trimmer Carburetor Replacement: 步骤 7 中的图像 1,3 RedMax Trimmer Carburetor Replacement: 步骤 7 中的图像 2,3 RedMax Trimmer Carburetor Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the gaskets and carburetor and replace them in the same order that they were removed.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 48
总计 5,376
