跳转到主内容
RedMax BCZ3050S Spark Plug Replacement
你所需要的
  1. RedMax BCZ3050S Spark Plug Replacement, Spark Plug: 步骤 1 中的图像 1,1
    • Look for the black plastic cover with ridges on the top of the brush cutter. Your fingers should be enough to pull the plastic off, but you may use a flat head screwdriver instead.
  2. RedMax BCZ3050S Spark Plug Replacement: 步骤 2 中的图像 1,1
    • Lift and separate the black plastic ridge covering from the spark plug..
    • Notice the spark plug still attached inside.
  3. RedMax BCZ3050S Spark Plug Replacement: 步骤 3 中的图像 1,1
    • Use a 3/8 in wrench to grip and twist the spark plug counterclockwise until it loosens and take it out.
    • You can use slip-joint pliers to perform the removal of the spark plug if you don't have a wrench.
  4. RedMax BCZ3050S Spark Plug Replacement: 步骤 4 中的图像 1,1
    • Insert the new spark plug and twist it in a clockwise motion until it is tight.
  5. RedMax BCZ3050S Spark Plug Replacement: 步骤 5 中的图像 1,1
    • Use the wrench or pliers and twist the spark plug in a clockwise direction to ensure a tight fit before placing the cover on top of the spark plug.
  6. RedMax BCZ3050S Spark Plug Replacement: 步骤 6 中的图像 1,1
    • Attach the bottom of the plastic cover to the top of the spark plug.
    • Firmly push down on top of the spark plug with the cover. This is enough pressure to connect the new spark plug to the machine.
  7. RedMax BCZ3050S Spark Plug Replacement: 步骤 7 中的图像 1,1
    • Once the cover is fully inserted, the repair is complete.
结论
另外一个人完成了本指南。
Saul Aceves
于10/13/20注册
166 声望
撰写一个指南
1指南评论
No, you use a spark plug socket to remove a spark plug.
Jose - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 954
