简介
This guide will show you how to remove the "ASF Assy" (automatic sheet feeder?) from the printer, and disassemble it sufficiently to lubricate the moving parts. It will not tell you how to remove the housing; which will be left for other guides.
todo: create guides for the prerequisites and add them to the prerequisites list.
你所需要的
This is the "ASF Assy" which we will be removing.
I have separated the "Panel FFC" (control panel) from the upper housing and reattached it to the printer for testing purposes.
Our first task is to remove the metal brackets which hold the Guide Roller in place.
metal brackets
Guide Roller
Note the vertical position of the screws holding the metal brackets. They move up and down to adjust the position of the Guide Roller. Mine were in the highest position, which puts the least amount of pressure on the Guide Roller.
Remove the screws.
Gently pull on the Roller Guide to release the metal bracket from the shaft.
Tilt the metal bracket sideways and off of the cam.
Because the Roller Guide flexes slightly, you can now shift the metal bracket toward the rear of the printer, to disengage it from the carriage assembly.
(needs new picture)
Rotate the metal bracket upward around the Roller Guide and remove it.
(needs another picture)
Disconnect the sheet feeder motor at the relay connector and unroute the relay wire from the 'ASF Assy'.
Separate the sheet feeder motor ground wire from the chassis ground.
Disconnect the FFC (flat flexible cable) (which links the main board to the relay board) at CN1
Disconnect the Paper Edge sensor at CN2
Disconnect the APG (automatic paper guide?) sensors at CN4 and CN5.
Disconnect the FFC which links the Paper Feed Encoder to the relay board at CN6. The Paper Feed Encoder's FFC is also tacked to the Sheet Feeder by double sided tape. Carefully separate the cable from the Sheet Feeder's frame.
Deroute the red & black APG motor wires from the ASF (automatic sheet feeder) housing.
Deroute the Flat Flexible Cables from the groove in the Automatic Sheet Feeder housing.
Congratulations, you just saved a 700$ printer.
2等其他人完成本指南。
2条评论
I am impressed by the quality of the instructions and photos. But do not why the ASF had to be removed. Is it to add a replacment? My concern is that my printer won't load paper. I am wondering whether I just need to increase the pressure on the pickup roller. With my printer the ASF mechanism is working it does try to pick up the paper.
*sigh* Well you can see it takes me a while to get back to working on projects that I start. Anyway, the reason I was taking out the sheet feeder was that the sheet feeder builds up too much friction which the printer doesn't like and causes the sheet of paper to be ejected without printing anything. By removing it, lubricating it, and fixing the rubber bits; the printer will print again. My fault was that I haven't finished writing the guide yet.
ciradrak -
