跳转到主内容
Reattaching the GEN 2 Wheelchair Foot Support
你所需要的
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 步骤 1 中的图像 1,3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 步骤 1 中的图像 2,3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: 步骤 1 中的图像 3,3
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: 步骤 2 中的图像 1,1
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: 步骤 3 中的图像 1,2 Reattaching the GEN 2 Wheelchair Foot Support: 步骤 3 中的图像 2,2
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
结论
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
于04/19/13注册
207 声望
创作了5篇指南
团队
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G8
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 789
