简介
If ever you disassembled the trimmer head in order to clean it thoroughly, and then had trouble assembling it back again, here's a step-by-step guide of how to achieve it!
你所需要的
Pick the thin lubrication sheet and put it ontop of the base. Align the 3 holes.
Now fit the base plate of step 1 onto the other parts, using the 3 T8 screws.
For the time being, do not tighten up the screws completely, just enough to hold all the parts together. This will allow you to gently lift the short hair trimmer with your finger - the knives will move downwards.
Now a step where you may need some extra patience: take the small spring, insert it into the groove of the short hair trimmer with the 2 ends, gently push it and insert the spring winding into the upper groove of the cast part.
Fit the two oscillation arms into the 2 pins of the wide hair trimmer first, and by spreading them.
Then tilt them to the inside, that the small latches keep it in place.
Gently lift the other ends of the arms above the pin of the cast part. Careful: you may break the arms if you lift too hard!
To disassemble your device, follow these instructions in reverse order.
6等其他人完成本指南。
3条评论
The spring can be seen in the picture on step 11. I used narrow pliers to get it in it's place.
I think the oscillation arms inverted in the pic. The little "R" letter is, in effect, on the left mounted.
Another question: what's the right face of the lubrication sheet?
