跳转到主内容
加入维修社区 - 创建账户
Rear Cover Removal
你所需要的
  1. Rear Cover Removal, Rear Cover: 步骤 1 中的图像 1,1
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. Rear Cover Removal: 步骤 2 中的图像 1,2 Rear Cover Removal: 步骤 2 中的图像 2,2
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. Rear Cover Removal: 步骤 3 中的图像 1,3 Rear Cover Removal: 步骤 3 中的图像 2,3 Rear Cover Removal: 步骤 3 中的图像 3,3
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. Rear Cover Removal: 步骤 4 中的图像 1,1
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. Rear Cover Removal: 步骤 5 中的图像 1,3 Rear Cover Removal: 步骤 5 中的图像 2,3 Rear Cover Removal: 步骤 5 中的图像 3,3
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. Rear Cover Removal: 步骤 6 中的图像 1,1
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
终点
另外一个人完成了本指南。
Nelson Oliveira
于02/03/23注册
741 声望
创作了4篇指南
2指南评论
HI, nice job, to remove the keyboard is it necessary remove the motherboard?
Pedro - 回复
No, do not need. Just need to remove battery. Very soon I will post a new instruction how to do it. Be insure to don't perfurate or blend the battery. It is fixed with a double tape.
Nelson Oliveira - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 33
总计 528
