跳转到主内容
加入维修社区 - 创建账户
Rear Axle Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Rear Axle Removal, Disconnect the spark plug wire: 步骤 1 中的图像 1,2 Rear Axle Removal, Disconnect the spark plug wire: 步骤 1 中的图像 2,2
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Rear Axle Removal, Chock the rear wheels: 步骤 2 中的图像 1,1
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Rear Axle Removal, Lift up the deflector: 步骤 3 中的图像 1,2 Rear Axle Removal, Lift up the deflector: 步骤 3 中的图像 2,2
    • Lift up the plastic deflector.
  4. Rear Axle Removal, Remove the grass bag: 步骤 4 中的图像 1,3 Rear Axle Removal, Remove the grass bag: 步骤 4 中的图像 2,3 Rear Axle Removal, Remove the grass bag: 步骤 4 中的图像 3,3
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Rear Axle Removal, Set the height adjustment lever: 步骤 5 中的图像 1,1
    • Set the height adjustment lever all the way forward, past the "A" setting, to loosen the axle spring underneath the mower.
  6. Rear Axle Removal, Tilt the mower on its side: 步骤 6 中的图像 1,1
    • Tilt the mower onto its side so the blades are facing out.
    • This may require two people.
  7. Rear Axle Removal, Unhook the axle spring: 步骤 7 中的图像 1,3 Rear Axle Removal, Unhook the axle spring: 步骤 7 中的图像 2,3 Rear Axle Removal, Unhook the axle spring: 步骤 7 中的图像 3,3
    • Reach underneath the axle, near the transmission, and pull the axle spring out towards the axle and down to unhook it.
    • Return the mower back to an upright position.
  8. Rear Axle Removal, Block up the mower: 步骤 8 中的图像 1,2 Rear Axle Removal, Block up the mower: 步骤 8 中的图像 2,2
    • Place the mower on blocks so each wheel is above the work surface and can rotate freely.
  9. Rear Axle Removal, Remove the wheel: 步骤 9 中的图像 1,1
    • Use a 9/16 inch socket to remove the wheel nut.
  10. Rear Axle Removal: 步骤 10 中的图像 1,2 Rear Axle Removal: 步骤 10 中的图像 2,2
    • Remove the wheel.
  11. Rear Axle Removal, Remove the axle components: 步骤 11 中的图像 1,2 Rear Axle Removal, Remove the axle components: 步骤 11 中的图像 2,2
    • Remove the wheel washer.
  12. Rear Axle Removal: 步骤 12 中的图像 1,3 Rear Axle Removal: 步骤 12 中的图像 2,3 Rear Axle Removal: 步骤 12 中的图像 3,3
    • Remove the dust cover.
  13. Rear Axle Removal: 步骤 13 中的图像 1,3 Rear Axle Removal: 步骤 13 中的图像 2,3 Rear Axle Removal: 步骤 13 中的图像 3,3
    • Use a pair of needle nose pliers to remove the gear retaining pin.
  14. Rear Axle Removal: 步骤 14 中的图像 1,3 Rear Axle Removal: 步骤 14 中的图像 2,3 Rear Axle Removal: 步骤 14 中的图像 3,3
    • Remove the drive gear.
  15. Rear Axle Removal: 步骤 15 中的图像 1,3 Rear Axle Removal: 步骤 15 中的图像 2,3 Rear Axle Removal: 步骤 15 中的图像 3,3
    • Use a pair of snap ring pliers to remove the snap ring from the driveline.
  16. Rear Axle Removal: 步骤 16 中的图像 1,1
    • Remove the snap ring washer.
  17. Rear Axle Removal: 步骤 17 中的图像 1,1
    • Use a 1/2 inch socket to remove the driveline bearing retaining bolt.
  18. Rear Axle Removal: 步骤 18 中的图像 1,3 Rear Axle Removal: 步骤 18 中的图像 2,3 Rear Axle Removal: 步骤 18 中的图像 3,3
    • Firmly pull the driveline bearing away from the mower.
    • This bearing is holding the driveline in place, so some components may shift around during removal.
    • This may require some force.
    • Repeat the last nine steps for the right side of the mower, starting with removing the right wheel. Once complete, continue to the next step.
  19. Rear Axle Removal, Remove the height adjustment lever: 步骤 19 中的图像 1,2 Rear Axle Removal, Remove the height adjustment lever: 步骤 19 中的图像 2,2
    • Remove the height adjustment lever from the left side of the mower.
  20. Rear Axle Removal, Remove the axle: 步骤 20 中的图像 1,3 Rear Axle Removal, Remove the axle: 步骤 20 中的图像 2,3 Rear Axle Removal, Remove the axle: 步骤 20 中的图像 3,3
    • Holding the left end of the axle with your left hand and the right end of the driveline with your right hand, firmly pull them in opposite directions—the axle to the left, and the driveline to the right.
    • While maintaining these opposing forces, squeeze both axles together.
  21. Rear Axle Removal: 步骤 21 中的图像 1,2 Rear Axle Removal: 步骤 21 中的图像 2,2
    • With the axle being pulled left and driveline being pulled right, force the left end of the axle out and down, around the end of the driveline.
    • If done correctly, there will be enough of a gap for the axle to clear the end of the driveline and drop down towards the work surface.
  22. Rear Axle Removal: 步骤 22 中的图像 1,2 Rear Axle Removal: 步骤 22 中的图像 2,2
    • Remove the axle.
终点
Carsten Frauenheim
于03/10/20注册
157,730 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,991篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 60
