简介
This guide should be used if the led lights on your razor hovertrax 2.0 stop working. You can choose to replace one side, but razor sells them in packs of two for replacements. The link to the replacement part brings you to the razor replacement part store, at the time of the creation of the guide we cannot access the direct link to the part as it is out of stock. This is the part number: Part# W15155045521.
你所需要的
Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
Get the back cover you removed over the battery, the led light housing is located here.
Removed circled screws and remove the light housing
