跳转到主内容
Razor A Handle Grips Replacement
你所需要的
  1. Razor A Handle Grips Replacement, Handle Grips: 步骤 1 中的图像 1,2 Razor A Handle Grips Replacement, Handle Grips: 步骤 1 中的图像 2,2
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: 步骤 2 中的图像 1,2 Razor A Handle Grips Replacement: 步骤 2 中的图像 2,2
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: 步骤 3 中的图像 1,2 Razor A Handle Grips Replacement: 步骤 3 中的图像 2,2
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
终点
另外一个人完成了本指南。
Jordyn
于10/09/12注册
544 声望
创作了5篇指南
团队
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G13
4 名成员
创作了10篇指南
一条评论
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 4,804
