跳转到主内容
Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement
你所需要的
  1. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: 步骤 1 中的图像 1,3 Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: 步骤 1 中的图像 2,3 Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement, Front Plates: 步骤 1 中的图像 3,3
    • Using an opening tool, pry off the the outer front plate.
    • It might take a bit of wiggling and time to loosen it and get it off.
    • Once the front plate is loose, pull it off.
  2. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: 步骤 2 中的图像 1,2 Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: 步骤 2 中的图像 2,2
    • Using an opening tool, pry off the the handle grips.
    • It might take a bit of wiggling and time to loosen and get them off.
    • Once they're loose, pull off the handle grip plates.
  3. Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: 步骤 3 中的图像 1,2 Razer Wolverine V2 Chroma RZ06-0401 Front Plates Replacement: 步骤 3 中的图像 2,2
    • Using an opening tool, pry off the Xbox logo plate.
    • Once it's loose, pull off the Xbox logo plate.
结论
Kaylin
于03/22/24注册
434 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-3, Botvin Spring 2024 UMass Dartmouth, Team 6-3, Botvin Spring 2024 的会员
UMASSD-BOTVIN-S24S6G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 36
