跳转到主内容
Razer Viper Ultimate Upper Shell Replacement
你所需要的
  1. Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 步骤 1 中的图像 1,3 Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 步骤 1 中的图像 2,3 Razer Viper Ultimate Upper Shell Replacement, Upper Shell: 步骤 1 中的图像 3,3
    • Gently use a flathead screwdriver to lift and take off the mouse skates, exposing the screws.
  2. Razer Viper Ultimate Upper Shell Replacement: 步骤 2 中的图像 1,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 2 中的图像 2,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 2 中的图像 3,3
    • Use a T5 hex-bit screwdriver to remove the four 2 mm screws from the bottom cover of the mouse.
  3. Razer Viper Ultimate Upper Shell Replacement: 步骤 3 中的图像 1,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 3 中的图像 2,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 3 中的图像 3,3
    • With the flathead screwdriver, carefully open the sides and back, unclipping the bottom shell from the mouse.
  4. Razer Viper Ultimate Upper Shell Replacement: 步骤 4 中的图像 1,2 Razer Viper Ultimate Upper Shell Replacement: 步骤 4 中的图像 2,2
    • Disconnect the three-pin connector cable under the Printed Circuit Board (PCB). Take off the cable with yellow, red, and black wires to reach the four 2.5 mm screws holding the battery and switches.
  5. Razer Viper Ultimate Upper Shell Replacement: 步骤 5 中的图像 1,2 Razer Viper Ultimate Upper Shell Replacement: 步骤 5 中的图像 2,2
    • Use a small Phillips-head screwdriver to remove the four 2.5 mm screws that secure the battery unit.
  6. Razer Viper Ultimate Upper Shell Replacement: 步骤 6 中的图像 1,2 Razer Viper Ultimate Upper Shell Replacement: 步骤 6 中的图像 2,2
    • Move the PCB with the battery from the old shell to the new one. Align the 4 plastic guide pegs with the holes in the PCB.
  7. Razer Viper Ultimate Upper Shell Replacement: 步骤 7 中的图像 1,1
    • Screw the 2.5 mm screws back into the switch pack and battery using the small Phillips-head screwdriver, following the layout of the new shell.
    • Adjust screw placement if needed.
  8. Razer Viper Ultimate Upper Shell Replacement: 步骤 8 中的图像 1,2 Razer Viper Ultimate Upper Shell Replacement: 步骤 8 中的图像 2,2
    • Reconnect the three-pin connector cables from step 4.
  9. Razer Viper Ultimate Upper Shell Replacement: 步骤 9 中的图像 1,1
    • Attach the bottom half of the mouse to the shell, ensuring everything is in its original place.
  10. Razer Viper Ultimate Upper Shell Replacement: 步骤 10 中的图像 1,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 10 中的图像 2,3 Razer Viper Ultimate Upper Shell Replacement: 步骤 10 中的图像 3,3
    • Screw in the four 2 mm hex screws on the bottom cover of the mouse (refer to step 2).
    • Finally, put the skates back on.
结论
Your Razer Viper Ultimate Mouse is now successfully reassembled in its new shell! Ensure all components are securely in place before use.
Nora Kanaan
于02/08/24注册
185 声望
撰写一个指南
团队
York University, Team 1-6, Morris Winter 2024 York University, Team 1-6, Morris Winter 2024 的会员
YORK-MORRIS-W24S1G6
4 名成员
创作了1篇指南
1指南评论
I think the model you have is different a T5 is to small for the screws in mine
Kodi Davis - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 38
过去 30 天: 183
总计 2,902
