跳转到主内容
加入维修社区 - 创建账户
Razer Viper Mini Cable Replacement
你所需要的
  1. Razer Viper Mini Cable Replacement, Cable: 步骤 1 中的图像 1,2 Razer Viper Mini Cable Replacement, Cable: 步骤 1 中的图像 2,2
    • Make sure to unplug the mouse before doing anything.
    • To access the screws, you will need to take off the information sticker on the bottom of the mouse.
    • Remember to take a photo of your serial number or write it down.
  2. Razer Viper Mini Cable Replacement: 步骤 2 中的图像 1,2 Razer Viper Mini Cable Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the three 2 mm screws from the bottom of the mouse.
    • When removing the screws, unscrew them each slightly and consecutively until you can pull them out with your hands.
  3. Razer Viper Mini Cable Replacement: 步骤 3 中的图像 1,2 Razer Viper Mini Cable Replacement: 步骤 3 中的图像 2,2
    • Use the plastic spudger to gently lift the backplate in order to access the internal components.
    • Insert the spudger into the bottom front of the mouse and slowly move it around the mouse which will release the backplate.
    • Do not try to jab the mouse with the plastic spudger with a large amount of force, this can damage the plating of your mouse.
  4. Razer Viper Mini Cable Replacement: 步骤 4 中的图像 1,2 Razer Viper Mini Cable Replacement: 步骤 4 中的图像 2,2
    • Use the plastic spudger once again to remove the shell of the mouse.
    • It is exactly like the previous step as you have to dig the plastic spudger gently into the bottom of the mouse and move it inwards to slowly release the shell.
    • You have now successfully removed the top shell of the mouse!
  5. Razer Viper Mini Cable Replacement: 步骤 5 中的图像 1,3 Razer Viper Mini Cable Replacement: 步骤 5 中的图像 2,3 Razer Viper Mini Cable Replacement: 步骤 5 中的图像 3,3
    • Use your Philips #0 screwdriver to remove five 2.5 mm screws from the board.
    • Unscrewing the top two screws will make it easier for you to get to the others after.
  6. Razer Viper Mini Cable Replacement: 步骤 6 中的图像 1,3 Razer Viper Mini Cable Replacement: 步骤 6 中的图像 2,3 Razer Viper Mini Cable Replacement: 步骤 6 中的图像 3,3
    • Use your small chain nose pilers to remove the molex power connection cable from the PCB.
    • Wiggle the port slightly while grasping the ends it in order to release it safely.
    • Do not use a large amount of force as you can easily damage your mouse's PCB.
    • Remove the PCB from the bottom plate.
  7. Razer Viper Mini Cable Replacement: 步骤 7 中的图像 1,3 Razer Viper Mini Cable Replacement: 步骤 7 中的图像 2,3 Razer Viper Mini Cable Replacement: 步骤 7 中的图像 3,3
    • Remove the old cable.
    • Make sure your new mouse cable has a 5-pin molex connector that is compatible with the Razer Viper's PCB.
    • Route the cable through the previous route that the original cable was in, remembering to press down with your Phillips #0 screwdriver so the PCB can fit nicely on top.
    • Lastly, plug the molex power connector of the new cable back into the PCB of the Razer Viper Mini and make sure it is tightly fitted.
  8. Razer Viper Mini Cable Replacement: 步骤 8 中的图像 1,3 Razer Viper Mini Cable Replacement: 步骤 8 中的图像 2,3 Razer Viper Mini Cable Replacement: 步骤 8 中的图像 3,3
    • Use the Phillips #0 to replace the five 2.5 mm screws to secure the PCB. Then, place the mouse shell back on.
    • Start from the top of the mouse and make sure it is securely fitted by the sound of the clicks before you start pushing the bottom.
    • Once the top shell is back on securely, you can put the backplate back on. Make sure it clicks when you put it back on.
  9. Razer Viper Mini Cable Replacement: 步骤 9 中的图像 1,2 Razer Viper Mini Cable Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #0 screwdriver to place the three 2.5mm screws into the bottom plate.
    • Now, once all of the screws are in and the mouse is assembled once again, you are ready to plug it back into your desired USB port and start using the mouse again!
结论
Remember to make sure all of the screws are tightly fitted and the molex cable is fitted tightly before you plug the mouse back into the USB source.
4等其他人完成本指南。
Jackie Tran
于09/18/21注册
241 声望
撰写一个指南
团队
York University, Team E-27, Melo-Thaiss Fall 2021 York University, Team E-27, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG27
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 121
总计 5,021
