跳转到主内容
加入维修社区 - 创建账户
Razer Tiamat 7.1 Cable
你所需要的
  1. Razer Tiamat 7.1  Cable, Cable strain relief: 步骤 1 中的图像 1,1
    • The problem.
  2. Razer Tiamat 7.1  Cable: 步骤 2 中的图像 1,1
    • There is a thin layer on top, glued with adhesive tape.
    • Use jimmy to slowly cut the adhesive and release the layer.
  3. Razer Tiamat 7.1  Cable: 步骤 3 中的图像 1,1
    • Open 6 screws
  4. Razer Tiamat 7.1  Cable: 步骤 4 中的图像 1,1
    • Inside.
  5. Razer Tiamat 7.1  Cable: 步骤 5 中的图像 1,1
    • Added a wire strip.
终点
2等其他人完成本指南。
Waqas Imtiaz
于03/21/16注册
171 声望
撰写一个指南
5指南评论
Could someone please send me a picture of the cable connected to the controller board. mine are all kind of disconnected, and I don't know wich one goes where. I have the Input Okay, but the Output are all disconnected.
I don't know if you can contact me on this site.
MrWisest - 回复
Hello, I just saw your comment. Here is the pinout of the wires going toward the headset from the sound mixer.
Here are the wires attached down the left side of the PCB (when looking at the bottom). From the edge of the PCB inward they are:
Solid copper, going to F_B
red/green spiral, F_L
Solid Green going to S_R
Red/copper spiral going to S_L
Solid red going to R_R
blue/green spiral. going to R_L
Above that a large black cable carries a white wire to M+ and a copper to M-
Here are the wires attached at the bottom of the PCB. From the corner of the PCB outward they are:
two blue/copper cables going to GND2
Red/Blue spiral going to Cen_L
Solid Blue going to Cen_R
Solid Black going to Sub_R
Solid Black going to Sub_L
Two Green/Copper cables going to 5V
Two Blue/copper spiral going to -
If you need the pinout for the other side of the board (towards the computer,) just ask.
TwixOps -
Hey,
i need the pinout for the other side of the board (towards pc). Could you please tell me that?
Best regards
Tristan Ott - 回复
Thanks TwixOps. This pinout saved my butt. My headset randomly stopped working and is our of warranty. Figured I’d crap it open and see what was up. A bunch of cables to the headset had come discounted somehow. Was able to repair it and save my $200 headset!
joe2chillo - 回复
My Razer Tiamet Headset USB Port creat over current to USB Port, So all other USB Port/devices are unresponsive when I plugged in Tiamet USB Connection. And It still not powered up. So How can I make it work normally?
Narmada District - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 3,505
