简介
If your Razer Phone rear camera is slow, blurry, or unresponsive, this guide will teach you how to replace the part.
你所需要的
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
即将完成!
结论
