跳转到主内容
Razer Phone Display Assembly Replacement
你所需要的
  1. Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 Razer Phone Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Display Assembly Replacement: 步骤 2 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Display Assembly Replacement: 步骤 3 中的图像 1,3 Razer Phone Display Assembly Replacement: 步骤 3 中的图像 2,3 Razer Phone Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Display Assembly Replacement: 步骤 4 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Display Assembly Replacement: 步骤 5 中的图像 1,3 Razer Phone Display Assembly Replacement: 步骤 5 中的图像 2,3 Razer Phone Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Display Assembly Replacement: 步骤 6 中的图像 1,2 Razer Phone Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 的会员
CPSU-WHITE-W19S19G6
5 名成员
创作了12篇指南
14条评论
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - 回复
Double sided tape.
Lucano -
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - 回复
Search on eBay. Phones are often parted out there.
Lucano -
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Lucano -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 106
总计 13,878
