跳转到主内容
Razer Phone Battery Replacement
你所需要的
  1. Razer Phone Battery Replacement, Display Assembly: 步骤 1 中的图像 1,3 Razer Phone Battery Replacement, Display Assembly: 步骤 1 中的图像 2,3 Razer Phone Battery Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Battery Replacement: 步骤 2 中的图像 1,2 Razer Phone Battery Replacement: 步骤 2 中的图像 2,2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Battery Replacement: 步骤 3 中的图像 1,3 Razer Phone Battery Replacement: 步骤 3 中的图像 2,3 Razer Phone Battery Replacement: 步骤 3 中的图像 3,3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Battery Replacement: 步骤 4 中的图像 1,2 Razer Phone Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Battery Replacement: 步骤 5 中的图像 1,3 Razer Phone Battery Replacement: 步骤 5 中的图像 2,3 Razer Phone Battery Replacement: 步骤 5 中的图像 3,3
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Battery Replacement: 步骤 6 中的图像 1,2 Razer Phone Battery Replacement: 步骤 6 中的图像 2,2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
  7. Razer Phone Battery Replacement, Battery: 步骤 7 中的图像 1,3 Razer Phone Battery Replacement, Battery: 步骤 7 中的图像 2,3 Razer Phone Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
  8. Razer Phone Battery Replacement: 步骤 8 中的图像 1,2 Razer Phone Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
  9. Razer Phone Battery Replacement: 步骤 9 中的图像 1,3 Razer Phone Battery Replacement: 步骤 9 中的图像 2,3 Razer Phone Battery Replacement: 步骤 9 中的图像 3,3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
  10. Razer Phone Battery Replacement: 步骤 10 中的图像 1,2 Razer Phone Battery Replacement: 步骤 10 中的图像 2,2
    • Carefully use the Jimmy to wedge the battery out of the phone.
结论
3等其他人完成本指南。
Bryan
于01/24/19注册
601 声望
创作了2篇指南
团队
Cal Poly, Team S19-G6, White Winter 2019 Cal Poly, Team S19-G6, White Winter 2019 的会员
CPSU-WHITE-W19S19G6
5 名成员
创作了12篇指南
5条评论
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - 回复
Where can I buy a battery and power button replacement for this phone
Kelly Sales - 回复
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - 回复
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - 回复
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 43
过去 30 天: 272
总计 14,519
