跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Razer Ouroboros Scroll Wheel Replacement
你所需要的
  1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 2,3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 3,3
    • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
    • Slide the palm rest out of place.
  2. Razer Ouroboros Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Razer Ouroboros Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
    • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
    • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
    • Slide the side panels off of the mouse.
    • Use your tweezers to take the lock switches off of the mouse.
    • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
  3. Razer Ouroboros Scroll Wheel Replacement: 步骤 3 中的图像 1,3 Razer Ouroboros Scroll Wheel Replacement: 步骤 3 中的图像 2,3 Razer Ouroboros Scroll Wheel Replacement: 步骤 3 中的图像 3,3
    • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
    • Slide the top panels off of the mouse.
    • Flip the mouse over, and the mouse casing should come off.
    • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
  4. Razer Ouroboros Scroll Wheel Replacement: 步骤 4 中的图像 1,3 Razer Ouroboros Scroll Wheel Replacement: 步骤 4 中的图像 2,3 Razer Ouroboros Scroll Wheel Replacement: 步骤 4 中的图像 3,3
    • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
    • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
    • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
    • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
结论
5等其他人完成本指南。
Preston Darling
于07/26/16注册
372 声望
创作了2篇指南
团队
一条评论
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 4,161
