跳转到主内容
Razer Ouroboros Lock Switch Replacement
你所需要的
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: 步骤 1 中的图像 1,2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: 步骤 1 中的图像 2,2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: 步骤 2 中的图像 1,2 Razer Ouroboros Lock Switch Replacement: 步骤 2 中的图像 2,2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: 步骤 3 中的图像 1,2 Razer Ouroboros Lock Switch Replacement: 步骤 3 中的图像 2,2
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
结论
另外一个人完成了本指南。
Preston Darling
于07/26/16注册
372 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 3,148
