跳转到主内容
Razer Naga Trinity LK-E5 Optical Encoder Replacement
你所需要的
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: 步骤 1 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: 步骤 1 中的图像 2,2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 2 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 2 中的图像 2,2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 4 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 4 中的图像 2,2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 5 中的图像 1,1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 6 中的图像 1,1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 7 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 7 中的图像 2,2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: 步骤 8 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: 步骤 8 中的图像 2,2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 9 中的图像 1,1
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 10 中的图像 1,1
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 11 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 11 中的图像 2,2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 12 中的图像 1,3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 12 中的图像 2,3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 12 中的图像 3,3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: 步骤 13 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: 步骤 13 中的图像 2,2
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 14 中的图像 1,2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: 步骤 14 中的图像 2,2
    • Remove the scroll wheel optical encoder from the scroll wheel.
结论
另外一个人完成了本指南。
一条评论
Where can we buy a replacement from?
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 54
总计 2,114
