跳转到主内容
Razer Naga Trinity LED Light Ribbon Cable Replacement
你所需要的
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: 步骤 1 中的图像 1,2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: 步骤 1 中的图像 2,2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 2 中的图像 1,2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 2 中的图像 2,2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 4 中的图像 1,2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 4 中的图像 2,2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 5 中的图像 1,1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 7 中的图像 1,2 Razer Naga Trinity LED Light Ribbon Cable Replacement: 步骤 7 中的图像 2,2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: 步骤 8 中的图像 1,2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: 步骤 8 中的图像 2,2
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 18
总计 1,503
