跳转到主内容
Razer Naga Expert MMO Top Plastic Shell Replacement
你所需要的
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: 步骤 1 中的图像 1,1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: 步骤 2 中的图像 1,1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: 步骤 3 中的图像 1,1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: 步骤 4 中的图像 1,1
    • Lightly pull the two plastic sides of the mouse to remove them.
结论
5等其他人完成本指南。
2条评论
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - 回复
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 27
总计 1,835
