跳转到主内容
Razer Naga Expert MMO Side Button Connection Strip Replacement
你所需要的
  1. Razer Naga Expert MMO Side Button Connection Strip Replacement, Top Plastic Shell: 步骤 1 中的图像 1,1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Side Button Connection Strip Replacement: 步骤 2 中的图像 1,1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Side Button Connection Strip Replacement: 步骤 3 中的图像 1,1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Side Button Connection Strip Replacement: 步骤 4 中的图像 1,1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Side Button Connection Strip Replacement, Side Button Connection Strip: 步骤 5 中的图像 1,1
    • Flip back the black plastic that holds the white connection strip in place on the side panel and the main panel.
  6. Razer Naga Expert MMO Side Button Connection Strip Replacement: 步骤 6 中的图像 1,1
    • Gently remove the white connection strip at each end.
    Where can I find the cable
    Anton Löfgren SPGY - 回复
  7. Razer Naga Expert MMO Side Button Connection Strip Replacement: 步骤 7 中的图像 1,1
    • Insert the blue striped ends into the white connection port on the mainframe as well as the frame with the buttons.
结论
一条评论
What is the code for the connection strip and how many pins does it have?
Thank you for the guide.
Tsuki Yomi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 2,339
