简介
Make sure to be careful you keep track of which screws you are using and which screws go where when disassembling. There are different types of screws used- one type being the screws used to separate the plastic shell and the other used to unscrew the scroll wheel itself.
你所需要的
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
另外一个人完成了本指南。
