跳转到主内容
Razer Naga Epic Chroma Top Casing Replacement
你所需要的
  1. Razer Naga Epic Chroma Top Casing Replacement, Razer Naga Epic Chroma Disassembly: 步骤 1 中的图像 1,1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Top Casing Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Top Casing Replacement: 步骤 3 中的图像 1,1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Top Casing Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Top Casing Replacement, Top Plastic Casing: 步骤 5 中的图像 1,1
    • Plug the new top casing's cable back into the socket on the right side of the circuit board near the middle.
    • Reassemble the device.
    • Test device to make sure the connections function correctly.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,809
