跳转到主内容
Razer Naga Epic Chroma Scroll Wheel Replacement
你所需要的
  1. Razer Naga Epic Chroma Scroll Wheel Replacement, Razer Naga Epic Chroma Disassembly: 步骤 1 中的图像 1,1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 3 中的图像 1,1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 4 中的图像 1,1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
    Thank you for this guide! I was able to get my mouse from 2014 open and clean it out
    Spam Account - 回复
  5. Razer Naga Epic Chroma Scroll Wheel Replacement, Scroll Wheel: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the single screw adjacent to the wheel.
  6. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 6 中的图像 1,1
    • Use your fingers to pull back on the plastic between the scroll wheel and the battery mount.
    • Keep pulling this tab gently towards the battery mount until the scroll wheel has been removed.
  7. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 7 中的图像 1,1
    • Unplug the wheel cable connecting to the board.
  8. Razer Naga Epic Chroma Scroll Wheel Replacement: 步骤 8 中的图像 1,1
    • Remove the scroll wheel from the mount.
结论
另外一个人完成了本指南。
一条评论
where can i get a replacement Scroll wheel?
William Jansen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 4,657
