跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Remove the teflon tape from the bottom of the mouse with a spudger.
    • Remove the teflon tape from the bottom of the mouse with a spudger.
  2. Remove the four screws with the Phillips head #00 screwdriver.
    • Remove the four screws with the Phillips head #00 screwdriver.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
  5. Gently pull up on the two side plastic plates.
    • Gently pull up on the two side plastic plates.
结论
6等其他人完成本指南。
Jordan Morgan
于2017年01月19日注册
806 信誉积分
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 9
过去的7天: 33
过去的30天: 231
总计 13,783
