跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Remove the teflon tape from the bottom of the mouse with a spudger.
    • Remove the teflon tape from the bottom of the mouse with a spudger.
  2. Remove the four screws with the Phillips head #00 screwdriver.
    • Remove the four screws with the Phillips head #00 screwdriver.
  3. Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Gently pull up on the two side plastic plates.
    • Gently pull up on the two side plastic plates.
  6. Take a nylon spudger and gently pry the battery pack from the device.
    • Take a nylon spudger and gently pry the battery pack from the device.
  7. Unplug the power cord from the circuit board.
    • Unplug the power cord from the circuit board.
  8. Plug the cord of the new battery into the socket on the bottom right of the circuit board.
    • Plug the cord of the new battery into the socket on the bottom right of the circuit board.
结论
4等其他人完成本指南。
Jordan Morgan
于2017年01月19日注册
806 信誉积分
创作了6篇指南
Do you have battery for sell?
BcTwenty9 - 回复
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Dan Mergens -
Anyone know where to buy a new battery?
Antony Lynch - 回复
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
Gooly - 回复
that battery appears to be very swollen………
Levi Coffey - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 41
过去的30天: 185
总计 6,227
