跳转到主内容
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement
你所需要的
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • If the damaged speaker is in the left ear piece, remove the left ear cushion by rotating it counter clockwise (ear piece with microphone boom). For the right speaker, the right ear cushion must be turned clockwise to remove.
    • For additional information on removing the ear cushions, reference the Ear Cushions replacement guide.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 2 中的图像 1,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 2 中的图像 2,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 2 中的图像 3,3
    • To get to the speaker you need to remove the six 5mm screws from the inner housing plate.
    • After doing this you can pull the housing apart exposing the speaker.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 3 中的图像 1,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 3 中的图像 2,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a knife to cut the glue around the speaker that is holding it to the assembly.
    • Once the glue is cut, pry the speaker out. Cut the wires at the base of the speaker and then replace them.
    • A solder gun will be needed to solder the wires onto the new speaker.
结论
2等其他人完成本指南。
Kyle Schober
于02/24/14注册
640 声望
创作了5篇指南
团队
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G8
3 名成员
创作了13篇指南
3条评论
Great guide!!
What speaker do i need to buy, where can i buy it ?
thank you!
Tom Van Aken - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 4,294
