跳转到主内容
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair
你所需要的
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 1 中的图像 1,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 1 中的图像 2,3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 1 中的图像 3,3
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 2 中的图像 1,2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 2 中的图像 2,2
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 3 中的图像 1,2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: 步骤 3 中的图像 2,2
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
结论
6等其他人完成本指南。
Kyle Schober
于02/24/14注册
640 声望
创作了5篇指南
团队
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G8
3 名成员
创作了13篇指南
4条评论
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - 回复
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - 回复
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
diego.riquelme.cortes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 5,971
