跳转到主内容
Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix
你所需要的
  1. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 1 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 1 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix, Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 1 中的图像 3,3
    • Remove the single screw using a Phillips #000 screwdriver.
    • Peel back the sticker on the mouse to reveal the two screws behind it.
    • Remove the two screws using a Phillips #000 screwdriver.
  2. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 2 中的图像 1,2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to pry open your mouse.
    • Detach the ribbon cable by squeezing the two grey latches and pulling it out gently.
  3. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 3 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 3 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 3 中的图像 3,3
    • Use your hands to lift the battery out of the mouse.
    • The battery's wire is still attached to the mouse, so use caution.
    • Use your fingers to detach the cable from the mouse.
  4. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 4 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 4 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 4 中的图像 3,3
    • Unscrew the five 1.4 mm screws using the Phillips #000 screwdriver.
    • Detach the wire that is connected to the scroll wheel.
    • Be gentle when pulling on the wire, or it could tear.
  5. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 5 中的图像 1,2 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 5 中的图像 2,2
    • Dip a cotton swab in hydrogen peroxide.
    • Clean the scroll wheel by dabbing the cotton swab around it.
    • Do not put too much hydrogen peroxide on the cotton swab or else the scroll wheel could get damaged.
  6. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 6 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 6 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 6 中的图像 3,3
    • Reinsert the wire back into its socket.
    • Insert and tighten the five 1.4 mm screws with the Phillips #000 screwdriver.
  7. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 7 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 7 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 7 中的图像 3,3
    • Connect the battery wire back into the latch.
    • Put the battery back into the battery holder.
  8. Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 8 中的图像 1,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 8 中的图像 2,3 Razer Mamba Wireless Gaming Mouse Scroll Wheel Fix: 步骤 8 中的图像 3,3
    • Connect the wire back into the latch.
    • Screw back the three screws using a Phillips #000 screwdriver.
    • Replace the sticker that was covering the top two screws.
终点
7等其他人完成本指南。
Kevin Velez
于04/04/22注册
319 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-99, Briggs Spring 2022 CSU Los Angeles, Team 4-99, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S4G99
1 名成员
创作了2篇指南
3指南评论
Listen screw driver is incorrect. Poor disassembly instructions that can easily lead to further irreparable damage to the mouse. Incredibly disappointing
Benjamin Parker - 回复
Cry me a river! If the screwdriver is incorrect i.e., doesn't fit into the screw correctly, don't attempt to make it work but instead try a different sized screwdriver. Wow! What a concept! Quit with the dramatics and just be glad that Kevin took the time to make this guide.
Michael Kolman -
Thank you for the teardown guide.
For anyone attempting this I have a couple notes to help you.
1. Unless you need to clean under the battery you DO NOT need to remove the battery and unscrew the 5 #000 Philips screws. As stated in this guide. This step is pointless and there is no need to take the time doing this. The screw seated to the left of the scroll wheel housing is crazy difficult to put back - unless you have tweezers. The scroll wheel can be cleaned without this step!
2. The 3 screws securing the mouse housing/body under the stickers are NOT #000 Phillips, they are T6 Star heads.
I completed this fix, but my scroll wheel still glitches and has a ton of jitter. I'm convinced this is a hardware/design issue.
JacobD - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 174
总计 14,391
