跳转到主内容
Razer Kraken Ultimate Volume Wheel Replacement
你所需要的
  1. Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: 步骤 1 中的图像 1,3 Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: 步骤 1 中的图像 2,3 Razer Kraken Ultimate Volume Wheel Replacement, Ear Pads: 步骤 1 中的图像 3,3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 2 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 2 中的图像 2,2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 3 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 3 中的图像 2,2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Volume Wheel Replacement, Speaker: 步骤 4 中的图像 1,3 Razer Kraken Ultimate Volume Wheel Replacement, Speaker: 步骤 4 中的图像 2,3 Razer Kraken Ultimate Volume Wheel Replacement, Speaker: 步骤 4 中的图像 3,3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 5 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 5 中的图像 2,2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 6 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 6 中的图像 2,2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Volume Wheel Replacement, Microphone: 步骤 7 中的图像 1,3 Razer Kraken Ultimate Volume Wheel Replacement, Microphone: 步骤 7 中的图像 2,3 Razer Kraken Ultimate Volume Wheel Replacement, Microphone: 步骤 7 中的图像 3,3
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 8 中的图像 1,1
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 9 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 9 中的图像 2,2
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 10 中的图像 1,1
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
  11. Razer Kraken Ultimate Volume Wheel Replacement, Volume Wheel: 步骤 11 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement, Volume Wheel: 步骤 11 中的图像 2,2
    • The volume wheel is located on the daughterboard.
    • Remove the single 6.0 mm Philips #00 screw.
  12. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 12 中的图像 1,1
    • Gently pull the board out of the housing.
    • Be careful not to tug on the connected ribbon cable.
  13. Razer Kraken Ultimate Volume Wheel Replacement: 步骤 13 中的图像 1,2 Razer Kraken Ultimate Volume Wheel Replacement: 步骤 13 中的图像 2,2
    • The wheel can be easily removed after removing the daughterboard.
结论
Alex Broggi
于10/24/22注册
342 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-4, Petersen Fall 2022 UMass Dartmouth, Team 1-4, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S1G4
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 37
总计 863
