跳转到主内容
Razer Kraken Ultimate Speaker Replacement
你所需要的
  1. Razer Kraken Ultimate Speaker Replacement, Ear Pads: 步骤 1 中的图像 1,3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: 步骤 1 中的图像 2,3 Razer Kraken Ultimate Speaker Replacement, Ear Pads: 步骤 1 中的图像 3,3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Speaker Replacement: 步骤 2 中的图像 1,2 Razer Kraken Ultimate Speaker Replacement: 步骤 2 中的图像 2,2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Speaker Replacement: 步骤 3 中的图像 1,2 Razer Kraken Ultimate Speaker Replacement: 步骤 3 中的图像 2,2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 Razer Kraken Ultimate Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 Razer Kraken Ultimate Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Speaker Replacement: 步骤 5 中的图像 1,2 Razer Kraken Ultimate Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Speaker Replacement: 步骤 6 中的图像 1,2 Razer Kraken Ultimate Speaker Replacement: 步骤 6 中的图像 2,2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
结论
Alex Broggi
于10/24/22注册
342 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-4, Petersen Fall 2022 UMass Dartmouth, Team 1-4, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S1G4
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 44
总计 487
