跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Computer Hardware,应参考我们的维修指南
  1. Razer Hyperflux Teardown, Removing the grip: 步骤 1 中的图像 1,1
    • Turn the mousepad over and peel off the grip with the white plastic layer.
    • The white plastic layer is glued to the device only on it's edges so if you're using the ifixit head pad you only need to put it on the edges.
    • Be sure to peel the grip + the white plastic layer. Removing just the grip and then the plastic layer will result in a very tedious process of trying to align the grip properly.
  2. Razer Hyperflux Teardown, Removing the PCB shield: 步骤 2 中的图像 1,1
    • Unscrew the 3 screws with a phillips head screwdriver
  3. Razer Hyperflux Teardown, Removing the PCB: 步骤 3 中的图像 1,3 Razer Hyperflux Teardown, Removing the PCB: 步骤 3 中的图像 2,3 Razer Hyperflux Teardown, Removing the PCB: 步骤 3 中的图像 3,3
    • Desolder the copper leads (red circle) and open the gate of the connector (blue circle)
    • You can now safely take out the pcb
    • For reassembly simply follow the steps in reverse
SgtBlade
于05/23/19注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 41
总计 1,845
