跳转到主内容
Razer Huntsman Tournament Edition Port Replacement
你所需要的
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: 步骤 1 中的图像 1,1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: 步骤 2 中的图像 1,2 Razer Huntsman Tournament Edition Port Replacement: 步骤 2 中的图像 2,2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: 步骤 3 中的图像 1,3 Razer Huntsman Tournament Edition Port Replacement: 步骤 3 中的图像 2,3 Razer Huntsman Tournament Edition Port Replacement: 步骤 3 中的图像 3,3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: 步骤 4 中的图像 1,1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: 步骤 5 中的图像 1,2 Razer Huntsman Tournament Edition Port Replacement: 步骤 5 中的图像 2,2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Port Replacement: 步骤 6 中的图像 1,1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: 步骤 7 中的图像 1,1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: 步骤 8 中的图像 1,1
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: 步骤 9 中的图像 1,2 Razer Huntsman Tournament Edition Port Replacement, Port: 步骤 9 中的图像 2,2
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: 步骤 10 中的图像 1,1
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: 步骤 11 中的图像 1,1
    • Remove the USB board.
结论
另外一个人完成了本指南。
Joseph O'Dowd
于10/25/22注册
383 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G3
5 名成员
创作了7篇指南
一条评论
how do i get a new port and where
Guardian Suit - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 23
总计 318
