跳转到主内容
Razer Huntsman Tournament Edition Chassis Replacement
你所需要的
  1. Razer Huntsman Tournament Edition Chassis Replacement, Keycaps: 步骤 1 中的图像 1,1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 2 中的图像 1,2 Razer Huntsman Tournament Edition Chassis Replacement: 步骤 2 中的图像 2,2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 3 中的图像 1,3 Razer Huntsman Tournament Edition Chassis Replacement: 步骤 3 中的图像 2,3 Razer Huntsman Tournament Edition Chassis Replacement: 步骤 3 中的图像 3,3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Chassis Replacement, Chassis: 步骤 4 中的图像 1,1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 5 中的图像 1,2 Razer Huntsman Tournament Edition Chassis Replacement: 步骤 5 中的图像 2,2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 6 中的图像 1,1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 7 中的图像 1,1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Chassis Replacement: 步骤 8 中的图像 1,1
    • Disconnect the internal cable.
结论
Ben Altman
于10/25/22注册
229 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 447
