跳转到主内容
加入维修社区 - 创建账户
Razer Huntsman Mini Feet/Risers Replacement
  1. Razer Huntsman Mini Feet/Risers Replacement, Feet/Risers: 步骤 1 中的图像 1,1
    • Turn off an unplug.
    • Flip the device to the back panel exposing screws or clips that attach the legs. Usually located near the corners or central support area.
  2. Razer Huntsman Mini Feet/Risers Replacement: 步骤 2 中的图像 1,1
    • The base model has clips on both sides of the legs securing it in place.
    • Carefully lift and slide out the broken leg.
    • If the leg is stuck use a plastic pry tool around the edges to loosen it.
    • Avoid using excessive force to prevent damaging nearby parts.
  3. Razer Huntsman Mini Feet/Risers Replacement: 步骤 3 中的图像 1,1
    • Once removed, clean out the space for your new replacement. Use a dry rag or a can of keyboard cleaner.
    • Take your new part and align it with mounting hole found on the sides snapping firmly back into place.
    • Check that the new stand/foot is level, secure, and stable.
    • Get back to gaming!
结论
Richm419
于03/18/25注册
97 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-6, Konn Spring 2025 UMass Dartmouth, Team 4-6, Konn Spring 2025 的会员
UMASSD-KONN-S25S4G6
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 168
