跳转到主内容
Razer DeathAdder V2 Pro Battery Replacement
你所需要的
  1. Razer DeathAdder V2 Pro Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the mouse over so that the writing on the bottom faces up.
  2. Razer DeathAdder V2 Pro Battery Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to remove the three pads on the bottom of the mouse.
  3. Razer DeathAdder V2 Pro Battery Replacement: 步骤 3 中的图像 1,2 Razer DeathAdder V2 Pro Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four 1.2 mm screws from each corner of the mouse using a T6 Torx screwdriver.
  4. Razer DeathAdder V2 Pro Battery Replacement: 步骤 4 中的图像 1,1
    • Use a nylon spudger to pry the back cover away from the mouse.
    • Starting from the lower corner of the mouse is strongly recommended. Once the tool is in, slide it in between the top and the lower part of the mouse, and run it around the edge of the bottom cover until it pops out naturally.
    • Be cautious not to crack the top and the bottom covers of the mouse.
  5. Razer DeathAdder V2 Pro Battery Replacement: 步骤 5 中的图像 1,1
    • Detach the white connector with red wires gently from the side that connects the side buttons to the PCB.
    • Be careful not to pull too hard on the connector to avoid damaging the solder that connects to the PCB.
  6. Razer DeathAdder V2 Pro Battery Replacement: 步骤 6 中的图像 1,1
    • Make sure the PCB is disconnected as shown before pulling apart the two halves of the mouse.
  7. Razer DeathAdder V2 Pro Battery Replacement: 步骤 7 中的图像 1,1
    • Place both the top and bottom pieces of the mouse on their backs.
  8. Razer DeathAdder V2 Pro Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the three 1 mm screws that hold the battery to the circuit board using a Phillips #1 screwdriver.
    • Remove the battery from the mouse.
结论
Tatiana Nzeba
于09/15/22注册
160 声望
撰写一个指南
团队
3条评论
What Voltage and mAh is the battery?
Nicoolodion - 回复
AliExpress ex. has the apropriate battery for this mouse.
It´s a battery with 1500mAh and 3,7V .
Claus Gärtner - 回复
Are you referring to LOSONCOER?
pikimouse -
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 271
总计 3,399
