跳转到主内容
Razer DeathAdder Chroma Motherboard Replacement Guide
你所需要的
  1. Razer DeathAdder Chroma Motherboard Replacement Guide, Outer Casing: 步骤 1 中的图像 1,1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 2 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 2 中的图像 2,2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 3 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 4 中的图像 1,1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 6 中的图像 1,3 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 6 中的图像 2,3 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 6 中的图像 3,3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 7 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 7 中的图像 2,2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Motherboard Replacement Guide, Motherboard: 步骤 8 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide, Motherboard: 步骤 8 中的图像 2,2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 9 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 10 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 10 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 11 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 12 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 12 中的图像 2,2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 13 中的图像 1,2 Razer DeathAdder Chroma Motherboard Replacement Guide: 步骤 13 中的图像 2,2
    • Remove the motherboard by grasping the sides and gently pulling upward.
结论
5等其他人完成本指南。
团队
Baylor, Team S5-G2, Williams Spring 2017 Baylor, Team S5-G2, Williams Spring 2017 的会员
BU-WILLIAMS-S17S5G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 58
总计 9,902
