简介
This guide outlines how to replace the fans in the Razer Blade Stealth 2017. The fans keep the laptop cool and prevent the other components from overheating. A fan replacement may be necessary if the fans are damaged, not turning on, or not functioning optimally. If the fans are making abnormally loud sounds when running, they may need to be replaced. Some tools are required for this replacement.
你所需要的
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
即将完成!
结论
