跳转到主内容
Razer Blade Stealth 2017 Fan Replacement
你所需要的
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: 步骤 1 中的图像 1,2 Razer Blade Stealth 2017 Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: 步骤 3 中的图像 1,2 Razer Blade Stealth 2017 Fan Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Fan Replacement: 步骤 5 中的图像 1,2 Razer Blade Stealth 2017 Fan Replacement: 步骤 5 中的图像 2,2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: 步骤 6 中的图像 1,2 Razer Blade Stealth 2017 Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: 步骤 8 中的图像 1,3 Razer Blade Stealth 2017 Fan Replacement: 步骤 8 中的图像 2,3 Razer Blade Stealth 2017 Fan Replacement: 步骤 8 中的图像 3,3
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: 步骤 9 中的图像 1,3 Razer Blade Stealth 2017 Fan Replacement: 步骤 9 中的图像 2,3 Razer Blade Stealth 2017 Fan Replacement: 步骤 9 中的图像 3,3
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: 步骤 10 中的图像 1,2 Razer Blade Stealth 2017 Fan Replacement: 步骤 10 中的图像 2,2
    • Use a plastic spudger to slide the fans out of the case.
结论
2等其他人完成本指南。
Helene Willits
于10/10/19注册
762 声望
创作了6篇指南
团队
Cal Poly, Team S11-G3, Regan Fall 2019 Cal Poly, Team S11-G3, Regan Fall 2019 的会员
CPSU-REGAN-F19S11G3
4 名成员
创作了7篇指南
一条评论
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 48
总计 2,188
