跳转到主内容
Razer Blade Stealth 2016 Speakers Replacement
你所需要的
  1. Razer Blade Stealth 2016 Speakers Replacement, Battery: 步骤 1 中的图像 1,3 Razer Blade Stealth 2016 Speakers Replacement, Battery: 步骤 1 中的图像 2,3 Razer Blade Stealth 2016 Speakers Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Speakers Replacement: 步骤 2 中的图像 1,2 Razer Blade Stealth 2016 Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Speakers Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Speakers Replacement, Speakers: 步骤 4 中的图像 1,1
    • Remove two 3.4 mm screws from each speaker using a T4 Torx screwdriver.
    • Remove the speakers from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 161
