跳转到主内容
Razer Blade Stealth 2016 RAM Replacement
你所需要的
  1. Razer Blade Stealth 2016 RAM Replacement, Battery: 步骤 1 中的图像 1,3 Razer Blade Stealth 2016 RAM Replacement, Battery: 步骤 1 中的图像 2,3 Razer Blade Stealth 2016 RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 RAM Replacement: 步骤 2 中的图像 1,2 Razer Blade Stealth 2016 RAM Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 RAM Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 RAM Replacement: 步骤 5 中的图像 1,1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heat sink.
  6. Razer Blade Stealth 2016 RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 RAM Replacement: 步骤 7 中的图像 1,2 Razer Blade Stealth 2016 RAM Replacement: 步骤 7 中的图像 2,2
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 RAM Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 RAM Replacement: 步骤 9 中的图像 1,1
    • Desolder the pins on the motherboard to remove the RAM.
    • WARNING: Be careful while using the soldering iron.
结论
一条评论
fanboy bowing down
Hal - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 28
总计 1,130
