简介
The motherboard is one of the most important components of the Razer Blade Stealth 2016 (Part # RZ09-01682E20). The motherboard has connectors in which the other circuit boards will be slotted. Essentially, all components lead back to the motherboard. If the motherboard fails, then so can almost every other component in your Razer Blade Stealth 2016. This guide will show you how to remove and replace the motherboard.
你所需要的
Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
另外一个人完成了本指南。
