跳转到主内容
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
你所需要的
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: 步骤 1 中的图像 2,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 2 中的图像 1,2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: 步骤 4 中的图像 1,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: 步骤 4 中的图像 2,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: 步骤 4 中的图像 3,3
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 5 中的图像 1,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 5 中的图像 2,3 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 6 中的图像 1,2 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the card.
结论
Kaitlyn Murray
于10/10/19注册
239 声望
撰写一个指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 950
