跳转到主内容
Razer Blade Stealth 2016 Keyboard Replacement
你所需要的
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 2 中的图像 1,2 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 7 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 7 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: 步骤 9 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: 步骤 9 中的图像 3,3
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 10 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 10 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 10 中的图像 3,3
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 11 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 11 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 11 中的图像 3,3
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: 步骤 12 中的图像 1,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 12 中的图像 2,3 Razer Blade Stealth 2016 Keyboard Replacement: 步骤 12 中的图像 3,3
    • Remove the keyboard from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 39
总计 835
