跳转到主内容
Razer Blade Stealth 2016 Heat Sink Replacement
你所需要的
  1. Razer Blade Stealth 2016 Heat Sink Replacement, Battery: 步骤 1 中的图像 1,3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: 步骤 1 中的图像 2,3 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: 步骤 1 中的图像 3,3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 2 中的图像 1,2 Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Heat Sink Replacement, Fans: 步骤 4 中的图像 1,2 Razer Blade Stealth 2016 Heat Sink Replacement, Fans: 步骤 4 中的图像 2,2
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
  5. Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Carefully lift and remove the left fan.
  6. Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 6 中的图像 1,3 Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 6 中的图像 2,3 Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 6 中的图像 3,3
    • Repeat steps five and six to remove the silver, right fan.
  7. Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: 步骤 7 中的图像 1,2 Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: 步骤 7 中的图像 2,2
    • Remove the four 3.38 mm screws around the black square using a Phillips #00 screwdriver.
  8. Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 8 中的图像 1,3 Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 8 中的图像 2,3 Razer Blade Stealth 2016 Heat Sink Replacement: 步骤 8 中的图像 3,3
    • Once the screws are removed, the piece can be gently lifted from the back of the device.
结论
另外一个人完成了本指南。
Lindsay Grant
于10/10/19注册
403 声望
创作了3篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2019 USF Tampa, Team S1-G4, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,263
